JanRV6UK
I have a question regarding the 068-001 valve from Grove ? is it basically a check valve that when ?closed? allow flow in ONE direction only ? i.e. you press the brake pedal and pressurise the calliper. Then when you ?open? the valve you push the check valve off its seat relieving the pressure allowing the oil to flow back into system (master cylinder and brake reservoir.
When you manipulate the leaver on the side of the valve you can feel a high point ? which for me is when you lift the valve of its seat (i.e. opening the valve) ....
Have I got this right ?
