Hi everyone,
"Bob",in the Aero Electric Connection says you should run all your grounds to a groundblock which is connected to the neg- side of the battery, ok but what if the battery is the back as it is in my -8,,, do you run all the wires to the back or can I run a #8 wire from battery to the firewall and add a grounding block there and connect the grounds.
Adam S.
Finnish Kit 8-![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Adam S.
Finnish Kit 8-
