I'm filling in the missing pieces between the firewall forward kit and the avionics packages.
Is there a preferred place to mount the ground tabs on the passenger side of the firewall; is there a preferred way to take the battery ground to it? The kit is designed to tie the battery ground to a nut plate location on the forward firewall; not sure the best way to tie the ground strip into that. Looks like I have to move it a bit....
Is there a preferred way to put the primary alternator shunt/ANL on the firewall?
Is the optional current sensor for the SB1B backup alternator useful?
any thoughts appreciated. I've looked at a lot of builder sites and lost in analysis....
