Hello
I have this nice ground bus that Stein Air has prepared for me. I want to mount it on the firewall in the typical orientation. Stud / Bolt to pick up negative battery cable protruding through firewall facing forward and the ground tabs facing aft.
i went and made a nice aluminum doubler for support. walking away BEFORE installing this i was thinking do i have any Galvanic action concerns here?
A stainless firewall that will be mated up to an aluminum doubler which is then mated up to the ground bus. i am assuming its copper.
i will be making a sandwich of dissimilar metals were there will be current passing through. is this a problem in your minds???
