Daida
Hi Folks!
i installed the ground adjustible Rudder pedals Yesterday.i am 6'4", therefore i put them in the most forward position. i have not rigged the whole brake system yet but i think that in my case, when i apply max brake when the Rudder is fully deflected to the same side that the pedals will hit the firewall.
has anyone out there expierience on this issue?
will it work out because the pedal deflection will not be as much to touch the firewall?
if there is an issue, what is the solution?
and please...........please let us not get into a discussion whether you need max brake and full rudder deflection or not, and what kind of situations could come up when you need max brake and full rudder.
i just want to be able to have max brakes with full rudder. period.
thanks in advance for your inputs!
Daida
Daida
