What's the size of that grommet in the inter-cylinder baffle where the #4 hose passes through? This is the hose that connects the fuel servo and the spider... Where can I get one (hopefully locally...)
Rad,
I have a rather large assortment of grommets. Let me know the approximate size you want and I'll check. I am also going to be in Charlotte the 24th to the 26th.
Firesleeve is your grommet. At least, that's the way it was on my Superior; the hole in the baffle was pre-drilled and the firesleeved hose passed through the hole with no room to spare.
