First, I would recommend taking a look at what others have done.
If you aren't already aware, Tim Olson's (
myrv10.com) and Deems Davis' (
deemsrv10.com) are two sites I would look at first. If I recall, both have pretty good photos of their Gretz install. I also have some photos on my site (
mykitlog.com/rleffler) too.
Like Eric mentioned, it's pretty straight forward. The biggest opportunity is determining where to install the components. Some folks have mounted the tube a little more outboard than others to get away from potential interference with the tie downs. I put the board on a nearby rib which can be easily reached through the wingtip.
One other item is to test the installation once you have everything installed. My original unit that was one of the last units Warren made had a short to ground in the thermistor circuit. Testing the unit on the bench didn't reveal the issue. It wasn't discovered until testing on the aircraft and the short to ground showed up.
Andrew (the new owner) was good to work with and he replaced all the components. Just attach a bag of ice to the pitot. That will cause the temp to drop quite quickly to activate the heating element. Just be aware of the pitot temp so that you don't melt the ice bag or burn your hand. You can also use a pot to simulate the thermistor and measure the resistance when the control board changes annunciator leds.
Speaking of the leds, if you are thinking about using Vertical Power, VP sells a board that allows you to interface the control board to the VP DU. This allows the pitot annunciation on the VP display instead of having to mount those three leds.
bob
