Renzo Corvetta
Member
Hello everybody.
My RV-14A with stock IO-390, two blade Hartzell propeller, P-Mags a is (at last) ready for the first flight s/n140169.
I am in the process of programming the instruments (G3X) with the appropriate green/yellow/red fields.
I kindly ask you if you could share your experience with me where to put the green/yellow/red markings for these indicators:
Fuel flow
Fuel pressure
Oil temperature
Oil pressure
CHT
EGT
Volts
Amps
MAP
RPM
Thank you much in advance!
Renzo Corvetta
Italy
Fuel flow
Fuel pressure
Oil temperature
Oil pressure
CHT
EGT
Volts
Amps
MAP
RPM
Renzo Corvetta
Italy
