Looking for advice in planning our Grass Strip/Homesite, it's 660'x2640' (40acres longways north) and relatively flat. I'm trying to draw up my proposal to send to the county for the Special Use Permit and want to be as accurate as possible.
I've walked the property with my "Dirt Guy" and his advice was to put the runway next to the west side of the property to work with the natural drainage. There is a tree row along the north half that I don't want to tear out as well as I would much prefer the house/hangar on the West side of the runway.
I was hoping to put the runway on the east side of the property, this would require a several small culverts as there is not enough slope for the larger ones needed. The smaller culverts would also require vigilance as the adjacent field debris would be flowing into the culverts. More expensive to build and work to keep up.
Pics of the property after 8 inches of rain this spring, You can see the drainage looking north.
Pic this fall after the beans were harvested looking south.
An initial sketch of a compromise trying to meet our Wants, This configuration makes it runway 02/200. "Dirt Guy" thinks this is a good plan, the south half of the runway would be built up slightly to funnel the water into the finger of trees on the south side. It would also dry out the southeast corner.
--Length--depends on the layout but 2300'+ is doable in all configurations
--Width--60' is a good compromise on cost, use and maintenance
--I'm told I want to use Bermuda grass (Kansas)
--Obstacles--Bury powerlines on north, live with trees on the south. House, Hangar, Trees 100' laterally from runway centerline.
--House--500'+ off the road
--Zoning requires 150' laterally for house from property boundary
--House and hangar on West side of runway, Hangar door facing east to the runway to avoid the prevailing north/south winds and summer evening sun.
--Retain some crop land for income
The angled truck tracks roughly represent the runway location as described above, looking south.
I appreciate any advice you can give!
![IMG_5625-L.png](/proxy.php?image=https%3A%2F%2Fphotos.smugmug.com%2FCrabtree-Airfield%2Fi-DjQMx7M%2F1%2Fa09f0f58%2FL%2FIMG_5625-L.png&hash=c63254272142d6e058e0d9baaddc9e33)
![IMG_5588-L.jpg](/proxy.php?image=https%3A%2F%2Fphotos.smugmug.com%2FCrabtree-Airfield%2Fi-37P5hz7%2F0%2F1f10fff0%2FL%2FIMG_5588-L.jpg&hash=5a2f2777b27d52673ff07929bef11688)
![IMG_5635-L.jpg](/proxy.php?image=https%3A%2F%2Fphotos.smugmug.com%2FCrabtree-Airfield%2Fi-R8NsdKT%2F0%2Fa3db790d%2FL%2FIMG_5635-L.jpg&hash=b0ef497af855210e2c081c7aab441509)
![IMG_5608-L.jpg](/proxy.php?image=https%3A%2F%2Fphotos.smugmug.com%2FCrabtree-Airfield%2Fi-MhBTxWZ%2F0%2F05a7bf73%2FL%2FIMG_5608-L.jpg&hash=1972c1bee4095ada24c95fefeebcfa58)
