For some reason the display on my new GPS175 seems to dim way too much at night, so at every startup I need to go into the settings and adjust the manual backlight offset. The manual says this setting should be retained between power cycles but it keeps resetting to 0%.
Anybody had this happen or experienced excessive dimming? I don't have an external dimmer circuit, so adjusting that way is not an option at the moment.
Chris
Chris
