Hi all,
This is probably a split question between GPS, the Comm forums, and probably a few others. I had to stick it somewhere.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As part of my over-rationalizing of whether I can afford to build a -9a, I'm planning a glass and an analog panel option. Right now I'm licensed for VFR, but will get IFR next spring. So the ultimate question is given both options, what do I need to fill out the IFR equipment list?
The glass would be dual SkyViews, with all of Dynon's options for integrated GPS, Mode S transponder, etc. I'm guessing here I just need a Nav/Com with a slaved heading/glideslope indicator. I was thinking either a King KX-155 or Narco MK12D Nav/Com.
For the analog panel, the same nav/com radio and heading/GS, combined with a Flight Cheetah FL-650 GPS and probably a GTX-330 if I went Mode S, or a Narco AT165K if I wanted to stick with Mode C for now.
Now, of course the big question/confusion... As I understand it, neither GPS is really certified, and thus I supposedly can't file /G. That's fine from a paperwork side. From a more practical standpoint, what types of IFR approaches and/or landings could I not do with this setup? Suggestions for additions or alternatives to the equipment to change that? I'd like to avoid connecting my wallet to the Garmin GNS or GTN vacuum.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
Thanks!
