GPS 2020 and Skyview
Pat Stewart
This morning I installed the new GPS2020 and V14 software. I also updated the transponder screen for the GPS2020.
I know have a big red x were my GPS screen once was and a message that says "No GPS Source Available.
I have run out of items to check and Dynon is closed today. Any ideas?
Pat,
You need to go into your serial port setup and tell it you have a 2020 GPS now, not a 250. They use different baud rates and protocols.
You also need to go into your transponder setup and tell it what GPS source to use for ADS-B.
More details are in section 8 of the SkyView install guide.
Did you change the GPS selection in the configuration menu?
Configuration ? SV-GPS-2020 only, Serial Port 5
Go to the Serial Port Setup Menu (SETUP MENU > SYSTEM SETUP > SERIAL PORT SETUP >
SERIAL PORT 5 SETUP) and then configure serial port 5 as follows:
SERIAL IN DEVICE: DYNON SV-GPS-2020
SERIAL IN FUNCTION: POS 1
SERIAL IN/OUT BAUD RATE: 115,200
SERIAL OUT DEVICE: NONE
Rob Hickman
Advanced Flight Systems - Dynon Avionics
Thank you guys, updating Serial 5 to GPS 2020 was the issue, thanks again for your outstanding customer support.
