Governor Adaptor
zav6a
I found a used PN 75150 cheap. Apparently for a O-360 A series. Anybody have the parts manuals that would say if it would fit a 0-320 B2A?
The eCopy of the manual that I have at home says you need a 75153. My paper copy of my 320 manual is in my hangar. The ecopy of the 360 parts manual says it uses the same 75153 governor drive adapter. This it the drive adapter that uses STRAIGHT fittings just like the fuel pump.
IIRC, there are TWO styles of governor drive adapters that we can use. The part number above is the NEWER style that uses the straight thread and o-ring fittings like the fuel pump uses. The older style (like I have on my 320) uses fittings that have PIPE Threads.
If it will fit on an O-360 it will also glove fit on an O-320.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
