This will go much quicker on the next airplane I build...had a little bit of head scratching between the plans and the instructions for the Matco wheels/brakes. Then had to do a little trimming on the pants brackets and on the included axle spacers. Also, the Van's axle nuts spun right on, but the ones with the oval cut hole in them (also purchased with the wheels/brakes) took quite a bit of force - so much so that we stuck with the original equipment for now and I'll call Monday to see if that should be expected or not, unless someone here has had a similar experience.
Next up, cabin top...
==dave==
