Mike S
Senior Curmudgeon
I have a question for the VAF collective mind-----(AKA, VAF database).
My cyl head temps are a bit higher than I would like, and I am thinking of a possible fix by making a set of inter cylinder flow diverters.
Here is the area where I think a problem exists---![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As can be seen, there is a large gap between the cyl bases, and the cyl fins.
I know that air, like water and electricity, is lazy and will take the path of least resistance, so I am thinking of blocking off the non finned area, and diverting the airflow in the finned area so it must go through, and not around, the fins.
My idea here is that in addition to the cyl fins getting better airflow, the fins on the head will also see increased air, and thus better cooling.
The next photo shows a paper pattern for the proposed baffle/diverter.
And here is a shot of the two areas for comparison.
Comments appreciated.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![P2070024.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F_A1sW0YKpru4%2FTVBRAeJJHZI%2FAAAAAAAACKo%2F9naF42e2d10%2Fs640%2FP2070024.jpg&hash=7d8f2179704fef896fd2c44957a300b3)
![P2070023.jpg](/proxy.php?image=https%3A%2F%2Flh4.googleusercontent.com%2F_A1sW0YKpru4%2FTVBQ_-zQK-I%2FAAAAAAAACKk%2FSmDKnpU0nFQ%2Fs640%2FP2070023.jpg&hash=c9a15560a169ca89cbe356ae37f5409b)
![P2070028.jpg](/proxy.php?image=https%3A%2F%2Flh6.googleusercontent.com%2F_A1sW0YKpru4%2FTVBRAtZrBDI%2FAAAAAAAACKs%2F38P0H1MF2hE%2Fs640%2FP2070028.jpg&hash=5f61951d6d5af7b70a10d5ff717cdea9)
