Good Rivet Gun and Drill
I went looking for tools, both air and electric, that would last a lifetime and I didn't mind spending a bit (or a lot!) more to get them. I also wanted to buy from a manufacturer that had a full line of tools - didn't want orphans, and wanted to be able to buy parts for these if I ever needed to.
Electric:
-Bosch 1020VSR cord drill 0-2100 rpm
-Bosch 1587VS cord jigsaw with variable blade orbit
-Bosch 3615 cordless drill 14.4V 2 speed ranges 0-400 and 0-1200 rpm with 15 clutch settings for screws. This one is a few years old, originally given to my dad as a present, subsequently inherited from him.
Air:
-Powerdyne 3/8" 90 deg angle drill (no P/N). Reversible with full size chuck. First air tool I bought. Cheap at about $100. Broke drive spindle but was amazed that parts still available locally several years after purchase.
-Atlas Copco LBB34 H033 pistol grip 3/8" drill. 0-3300 rpm oilless.
-Atlas Copco LBV24 S032 90 degree angle drill. 0-3200 rpm oilless. Extremely small tip with collet type drive. A pain in the butt to change drill sizes, but we only really need 3 or 4 sizes. Didn't think I was going to use it much, but when I was finishing the wings it was invaluable.
-Atlas Copco RRH 04P-12 TS trigger start pistol grip rivet gun (2X). Has a very nice teasing trigger which rotates to control the air pressure. Very convenient, don't need an external regulator. First gun I bought and thought it would do for all my riveting as it listed 3/32 to 3/16 nominal capacity (aluminum rivets), but was disappointed in the performance on -4. Frequency is 66 Hz, energy/blow is 1.5 ft-lb. It gets hard to control with the high frequency on anything larger than -3. However it's great for -3.
-Atlas Copco RRH 06P TS trigger start pistol grip rivet gun (3X). Bigger brother to the RRH 04P with the same type of trigger. I bought this after I had trouble driving -4 rivets through the aileron brackets among other places. Frequency is 36 Hz, energy/blow is 4.4 lb ft. Listed as 5/32 to 1/4 nominal capacity (aluminum rivets). Much easier to control on -4 and larger rivets. In comparison with the RRH 04P the rivets almost seem to "flow" when driven with this gun. Both guns have an air damping piston which reduces the vibration transmitted to your hand. Atlas Copco also has spring dampened bucking bars which are excellent, but too expensive even for me. I use a tungsten bar almost exclusively now.
-Atlas Copco LSF 17S300-2 die grinder 0-30,000 rpm. Use with both die grinder bits and 2-1/2" fiber cutoff wheel
-Chicago Pneumatic CP 0214 compression riveter with several yokes.
I am totally satisfied with these tools with the exception of having to buy the second riveting gun. If I could only buy one, I would buy the RRH 06P (larger one), but I am glad I have both. The RRH 04P is 7" long and the RRH 06P is 9" long. Sometimes you need the smaller gun.
