I had cause to disconnect the ground from my SL40 tonight. On starting the panel up to check some other items, the SL40 came to life! I checked that there wasn't a duplicate ground wire, there wasn't so my only conclussion is that the actual unit is getting ground from the frame which in turn is connected to the panel. Is this a good or a bad thing? and if bad, does the frame need issolating? ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
