Has anyone else ever had this error? "GNX 375 NEEDS SERVICE" It's hard to find the message in the documentation but I found it buried in the maintenance manual. The 375 appears to be working in its entirety however I continue to get this message. Stien has provided a new config module which we replaced...same error. We have sent screen shots that shows green checks in the settings. The wires and pin outs appear correct and are confirmed by the green checks in configuration mode. Before I pull it and send it back I was wondering if anyone else has plowed this ground already. If so what did you do to clear the message?
