So I would need to use serial port #3 on the GNS480 to provide the 330ES with position data.
Fortunately, this GNS480 has the most current software installed
Garmin Service Bulletin 1519: GNS 480 Software Upgrade to Version 2.4 with GPS Software Upgrade to Version 5.1
Any idea which serial ports on the 330ES should be connected to the #3 port on the GNS480?
Many Thanks,
Mike Cingari
Hi Justin,
I am using GNS480 Installation Manual dated March 2015 560-0982-01 Rev M
and the GTX 330/33 with ADS-B Out Installation Manual 190-00734-10
June 2013 Rev. 3
Please confirm: connect the RS232 from the GNS480 port 3, into the GTX330ES RS232 port 2.
I have not yet upgraded the GTX330 to the ES model and when done it will have the most current software version.
Can the 330ES get ads-b position data from port 6 of the 480 to port 1 of the 330ES, as that is the current RS232 connection between the units. If so, can I just install the 330ES into the tray, with no additional wiring, and configure the system for ads-b operation?
Mike
Port 6 on the GNS 480 can be set to GTX + or GTX w/TIS+, and will provide remote control, ADS-B Compliant GPS Data, and optionally TIS-A traffic information. If using either one of these, you do not need to use ADS-B+ from port 3.
Justin
Skysailor,
Port 2 input on the 330 is being used by fadec w/alt. Altitude encoder data for the transponder that originates from the EFIS. Don’t want to mess with that!
I will relocate 480 pins to port 3 and leave port 1 on the 330 as is.
When you activate adsb+ on port 3 tx does it allow any options to be selected on port 3 rx? I think not.
I really do not need remote control of the 330 from the 480 so serial port 3 to serial port 1 will work for my needs.
Mike
