Hello All
I just installed a GNS 480 in my RV-4 this summer which interface with my Skyview via Serial Port and I was wondering if someone else here having the same set up could help me out..
After loading a flight plan in the 480,are you able to see the flight plan on the map ( I do ) and once you have loaded an approach if you are also able to see the approach's waypoint on the map ( I don't )
If yes to all on that, could you tell me what you had to do to make the approach waypoint showing on the map???
Any special set up I should know about or if they simply don't appeared on the map.
Bruno
Bruno
