Hello All
Is there anyone here who has ever wired a GNS-480 to a Mid-Continent MD-222-406 CDI or have any idea on how to do that??
I wired mine and it is working as it should ( GPS Approach and all) but when I select VOR , it is really erratic, by that I mean when trying to track a radial, if I move the OBS just a degree in either direction or so it goes full deflection so it is basically useless...
If I used the HSI on my Skyview, it's working just fine so the problem is between the 480 and the CDI..
As far as I know the connections should be ok but it will be nice to cross-check with someone who has done it..
Thank you
Bruno
Thank you
Bruno
