mill2978
I've added a GMU 11 to my G3X and am getting a network error, however the CAN BUS Is working enough to pass along the serial number, software version, etc. It also shows a network error rate of 0%. Any suggestions on troubleshooting?
The roll servo in the right wing was the end of the can bus previously(other end is the pitch servo by the bell crank). I removed the jumper that indicated it was the end and am using the can bus terminator at the GMU 11. I've verified voltage, double checked power pins, can bus pins, shield grounds, the node splices I made in the wing at the auto pilot servo,etc. It all checks out.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
