I had seen postings at some point where people were suggesting the use of the GMC "Jimmy" or similar overhead console in the RV-10. It includes four point lights, a couple of storage compartments, and a clock/compass/OAT display. So, I picked one up for about $45 including shipping but have no idea how to make the display come to life. The lights work in bench test, but I am hoping that someone who has successfully installed one can help me here.
A few questions:
1. I am guessing the compass is on the board already and an external computer is not needed for OAT or compass. Is this correct?
2. The wire colors don't seem to match the ones from the GM dealer/shop manual though the OAT wires do, and I got a $15 temperature sensor to put somewhere in outside contact.
My six wires are the following colors:
gray - dimmer?
black/white stripe - ground
lt green/black stripe - OAT signal
beige - ?
dk green - power
dk brown - ?
Any suggestions on the minimum wiring I should need to make this work with the OAT probe?
3. Any recommendations on the simplest way to mount the unit to the ceiling safely?
A few questions:
gray - dimmer?
beige - ?
dk green - power
dk brown - ?
