trevor51590
I'm New Here
Hey all,
I got working on wiring up my intercom with a GMA340. When I plug the headphones in I hear audio no issue, and when I plug the mic in the mic jack I can hear myself on the intercom just fine. I have an old PTT similar to https://www.aircraftspruce.com/catalog/avpages/ptt_switch2.php?clickkey=997456
When I plug it in, the intercom goes away. When I key the mic, it sounds like it pushes out though. I wired it as per the explanation for microphone in the second image. I used a shielded 3 wire to connect the mic with the barrel to pin 35, the ring to pin 33, and the tip to pin 34. Did I wire the mic jack correctly? I’m trying to find out why when I plug the PTT switch into the mic jack I would lose intercom. This particular PTT switch came from a portable intercom. I assume they all work similarly but maybe not?
Thanks!
Thanks!
![RoXYFl7.jpg](/proxy.php?image=https%3A%2F%2Fimgur.com%2FRoXYFl7.jpg&hash=47586d12bb9745fd82504beff358bf7c)
![yXbvqnu.jpg](/proxy.php?image=https%3A%2F%2Fimgur.com%2FyXbvqnu.jpg&hash=9c2f9a52fde123bb6d382c67cdcdff5d)
