jsisk
Member
My recent RV-14 build used common plastic trim strip to finish/soften the aft edge of the instrument panel glare shield - easy, common solution. However, my night lighting LED flood strip on the bottom of the glare shield was directly visible and overpowering. I found an automotive trim on Amazon that is a little larger and softer, but also includes a sealing bulb in the profile that extends downward enough to shield the LED strip from direct view. Really makes a nice difference. The PN on Amazon is B07HR3NWY8, costs about $10 for 5 ft. See images.
