I have a well-lighted paint area (12 8-foot tubes on a white ceiling 28x20'). Still, I was having problems really seeing paint application in the spray gun fan, in particular with clear. I needed some glare.
Here's the cure. The 4-foot double fixtures are about $9 each at Home Depot. They're pop-riveted together with a section of .060 scrap aluminum. The base is a scrap steel plate with a length of 1" square tube welded in the middle. I put some old casters on the base too. Drill two holes in the upright so you can mount the light high or low with a single 1/4" bolt. Low is good for spraying vertical panels, high for horizontal. Make two and put one at each end of the room. Position them so they light the workpiece at a flat angle.
For about $50, it made a big difference in my paint work.
![](/proxy.php?image=http%3A%2F%2Fimg296.imageshack.us%2Fimg296%2F5653%2Fglarelight1hq1.jpg&hash=140b03a07aa8cc60c768fe4b3009b609)
![](/proxy.php?image=http%3A%2F%2Fimg521.imageshack.us%2Fimg521%2F8389%2Fglarelight2gp7.jpg&hash=25dbedced42d07a5d89794787e561d41)
![](/proxy.php?image=http%3A%2F%2Fimg223.imageshack.us%2Fimg223%2F3821%2Fglarelight3kh1.jpg&hash=41d372f34b928a85a917b657aaa48916)
