Has anyone used T-88 adhesive for the trailing edges?
I'm sure I can remember some reference to it, but I've no idea where it was. Seems to me it might be a lot nicer than Prosealing things?
I used T-88, and it worked fine, but not on my first attempt.
My first attempt was just an experiment with some hardware store aluminum to see if that epoxy would work ok here. I made a sandwich out of two thin sheets and a 1/16" strip to simulate the actual trailing edge components. I drilled and countersunk a long row of holes so I could practice the riveting also. I
lightly scuffed and cleaned the mating surfaces (Dawn and water, then acetone), applied the T-88, clecoed it, and waited a day or so. Soon after I started working with it, I managed to apply a slightly bending, or twisting to the assembly, and it split apart; the epoxy let go along a long stretch of the joint.
I tried again, except this time, I scuffed more heavily, then cleaned again. This time it held together very well. So I proceeded to use it on all of the tail components, using Van's method of backriveting, and had no trouble at all. All trailing edges came out very nicely.
(PS: this is ancient history, my memory may be a little fuzzy on some of the details)
(PS #2: I later built my flaps and ailerons without any adhesive in the trailing edge, and they also came out perfectly straight)
Happy Building!
John
