The RV 10 gear leg fairing seems to be designed to "float" on the gear leg and relies on the intersection fairings to keep it in trail to the gear leg but is always contacting the wheel pant since there is nothing to suspend it upward. This is different from my rv6 fairing where a tab is created which allows a clamp to go around the leg capturing the fairing. Is this an issue long term at the wheel pant/ fairing contact point? Should the fiberglass be built up at that point?
