MLG flange fitup
Do you have at least most of the bolts slid thru the bracket into the spar to ensure you have the correct left-right alignment, especially the spar "midline foot"? Mine was a tight fit, and took a little jiggling to get all the bolts through the spar, then did the fuselage match drilling. This weekend I bolted my brackets in and had no problems. (I tried to insert a picture but can't figure out how).
Mike "Bladerunner" Rhodes
RV-9A Fuse
