Junglepilot
Gear tower hardware question (pre-1 vs -1)
First my kit is a pre -1 from 2003. I am converting this (8A) to 8. Ken Krueger worked closely with me and we came up with the parts for the conversion. All has worked excellently.
Now, the question I have arises from the fact that my plans are pre-1 and my new parts are all -1 (pre-punched) This has made the transition very easy, thanks to Ken's wisdom. However once in a while the parts in the pre-1 plans are slightly different than the -1 as Ken redsigned a number of parts so that there were less parts. For example the 822 weldment on my plans calls for an 822B angle piece to be fabricated onto the 822, yet the 822 weldment I got from Vans has that piece already welded on. They streamlined a lot turning two piece fab processes into one piece. Very nice.
That's just a little background so you'll understand why I am asking this.
So I am dimpling the F-820 [forward] skins and in the area with all the holes are that will eventually attach the the 820 weldment, the hardware call-outs on my pre-1 plans show the following: (Drawing 28)
Here's the pic of the detail on DWG 28 (pre -1 plans):
So the questions is: Do the new -1 plans call for the 509 screws? The reason I ask is that the pre-punched holes in the new 820 skins in that area and other parts (822 weldment , et al) are all pre-punched with the same holes (for an AD4 rivet) i.e. SMALLER that required for the AN509 screws. I kind of expected to see pre-punched holes for the 509 screws closer to the 509 screw dia.
I am guessing I just need to redrill the holes to the correct size as I know all the holes a just undersized a bit anyway.
Hope this questions is clear. I just want to make sure the newer -1 plans do not call for a different fastener than the AN509 screws.
I probably could have waited until Monday and called VANS but I'm there today and want to move forward but not at the expense of ordering new parts.
- AN426AD4-7
- AN509-8R10 (CS Screws)
![drawing 28.jpg](/proxy.php?image=http%3A%2F%2Fwww.junglepilot.org%2Fvaf_forums%2Fdrawing+28.jpg&hash=9969f35226246d58b8291c9f89d6de95)
