I have been measuring on my grove landing gear for several work sessions. About 2 hours of measuring and remeasuring. I drilled tonight and then discovered that my jigging setup has resulted in both gear legs in near perfect alignment with the tail and about a 1/4 degree toe-in on each gear leg. Vans sells 1/2 and 1 degree tappered plates but not 1/4 degree. Should I be concerned or build on? I am quite a prefectionist and this is killing me.
