Turns out the gear housings are a few thousands under the size if the leg diameters. I intend to work on them with a small hone................any other creative solutions??
These are more than snug. The bore is literally .02 smaller in diameter than the inner end of the gear leg. Until you get at least a .005 clearance or so, there is no chance of those parts going together. I measured mine at about .01 clearance before checking Mike's, and his is definitely a negative .02.The snugger they are the better in my opinion. I think we used never seize on final installation.
That is pretty much what mine are, but the gear sockets in question are around 1.72-1.73. Will be interesting to see what Van's suggests.Gear legs= 1.749" and sockets= 1.755". Right where they should be.
... but Dremel's are not very good...
