The next step after installing the motor mount on the firewall is insertion of the gear legs. It’s not possible as the bottom corner of the fuselage and fire wall interfere covering about a third of the hole. Have other TD builders experienced the same issue? Is this normal? I’ve emailed support at Vans twice to see if this is normal or if I have the wrong motor mount but I get no response. I don’t want to do any cutting unless I know this is normal.
Jay
Jay
