The upper and lower halves of the gear leg fairings on my RV6 fret against each other. The result is a lot of that streaky aluminum crud around the overlap. What's the fix?
Mine do the same thing. There is always black crud puking from separation between the halves. They didn't do that till I installed the gear leg stiffeners, but that istallation altered the fit a little bit. I'm about to go to fiberglass fairings.
