BlackRV7
OK, back to asking construction pictures: the instructions call for one to cut the gear leg template out and "position the trim template over the fairing using the molded-in scribe lines". I see the scribe line location on the drawing and the reference to "this point 3 7/32 from scribe line" on the drawing but what is the deal with the molded-n scribe line. I take that to mean it should be present on the leg fairing.............and there are no molded in scribe lines on the fiberglass gear legs. What gives? Where do I position the template to start making cuts?
