Interference fit
For most close tolerance fastener installations involving non moving structures ( like a spar) there should be a slight interference fit. Typically it is .0005 to .0015 Do not turn the reamer at high speeds.
This is for softer metals structure such as aluminum and bronze, and the fastener being installed is steel or equivalent.
I hope this helps!
