I'm installing the lower fwd fuse skins, and the instructions dont mention opening the holes for the AN4 bolts to be put in outboard, but the plans call it out. Isn't now the right time to open up those holes as opposed to later when the floor might interfere with drilling them open?
Is there an optimum size or just whatever is needed....? I assume you can slide a plug into that hole once the gear are on?
