gear alignment
bobnoffs
i recently checked my gear alignment on my 12. i have adjusted the camber but i need the voice of experience here. my left main is .24 toe out. my right main is ,175 toe in. shims are in .25 increments. would i be more likely to improve by just going .25 deg toe in on my left or .5 deg toe in? i know try it and see is the most likely answer but maybe there is some rule of landing gears out there. as it is it does pull left on landing thanks
