In process of installing O-320 in place of failed Subaru engine on our RV-7. The old set-up had low pressure and high pressure in-line fuel filters.
With the Lycoming, and the typical Vans fuel line arrangement a gascolator is supposed to provide some protection against fuel contamination.
The recommended mounting location is not the low point in the fuel system, for a resting tail dragger, so it probably doesn't work for water trapping. Also on the firewall at the bottom of the cowl seems like a really impossible place for access to drain the gascolator.
Any thoughts on the merits or requirement for a gascolator most appreciated.
