I installed my gascolator per FWF plans (-9A) prior to installing the engine mount. I realized way too late that the drain for the gascolator is partially blocked by the lower horizontal member of the engine mount. And there is no cut-out or access to the gascolator per the plans in any case - necessitating removal of the lower cowl to actually sump the drain. All in all a complete mess. There are of course two sumps on the wing tanks, but these are not actually the lowest point in the system.
Posting here to see if others ran into this and what their solution was. Thanks for any thoughts/advice.
