I've been meaning to post this for a long time. Each time I think about doing it, I consider how trivial it is, and that I may well be the only person on this earth that did not know this. So, here we go. While at the RV fly-in at Petit Jean last year, I was chatting with another RV-12 guy, and the subject got around to gas caps. I mentioned that often I had difficulty in removing the cap. I made a nice tool for lifting the tab, but the well fitting "O" ring made the cap removal a real struggle. We happened to be standing by my RV-12, and he politely demonstrated a simple procedure. All it takes is a little push down on the stem, and the cap can be easily removed. What a simple fix for an aggravating problem. After lifting the tab, that little push down on the strm relieves the tension that is against the "O" ring. This may not be much help to most of you, but if it just saves one guy from this struggle that I have been having for over a year, it was worth posting.
What a fantastic bird!!!..........Tom
