Garmin transponder update
rcarsey
Just FYI, if you happen to have a laptop and USB cable (with the square Type B end on it) handy:
https://www8.garmin.com/support/download_details.jsp?id=15964
GTX 45R/GTX 345 Series ADS-B Software Version 3.41 contains the following changes:
  1. Corrected an issue described in Garmin Service Advisory 23009 that prevents the appearance of some traffic targets while the Basic Surface Situation Awareness (SURF) application is active.
  2. Corrected an issue where some 1090ES ADS-B and ADS-R surface targets may erroneously appear as directional.
  3. Removed transmittal of Non-Performing Emitter (NPE) traffic data from HSDB to other connected Garmin devices.
  4. This addresses a traffic display compatibility issue in some G3X™ installations. NPE data is still transmitted using Connext® over wired serial interfaces and Bluetooth.
  • 23034.pdf
