I have a garmin SL40 radio connected through a Garmin 240 audio panel.
Two issues:
Issue One: Loud white noise when PTT pressed.
I have tried different headsets, turned off Garmin 240, reprogrammed sidetone to 000 ( follows volume control), reprogrammed mic gain to lower level.
Although the white noise (hisss) is very loud during transmission others report receiving me at 5 by 5 .
White noise volume is lower at low RPM, it is not alternator whine.
When engine not running white noise is present for only two seconds after PTT pressed.
Issue Two: I can hear nearby AM radio in hanger through headset when PTT pressed.
I double checked grounds to plugs and made sure they where isolated from ground at plug end.
Thoughts please
Peter
Two issues:
Thoughts please
Peter
