Guys: I've searched the archives for the answer and couldn't find it. I have a Nexus 7 with the Garmin Pilot App and have discovered a glitch I consider a major problem. If I want to enter coordinates for way points in Degrees, minutes, seconds, mostly Degrees and Minutes, my way point is not where I expected it to be, but several miles away. I discovered that the Garmin Pilot App is converting the Degrees, Minutes, Seconds to Degrees and decimal degrees and plotting that coordinate. Am I doing something wrong or did Garmin decide that Degrees, Minutes, Seconds is not the conventional aviation format any longer? Dan
