I have a Garmin stack in my plane that has worked flawlessly for almost two years. About a month ago, I started to hear an audio noise through the headset that was a steady clicking sound about once every one second. Not overly loud and not enough to interfere with communications, but it is annoying. It goes away for about 5 seconds when you talk or there is radio traffic, then returns. I have traced it to the Garmin GTX 327 transponder. When I turn that off, the clicking stops. It almost sounds like the I am hearing the transponder transmit its ping? I have the GMS 340 audio panel also. Any ideas of a possible solution before I pull theses out and send them in to the avionics shop? I also unfortunately am using a BMA power panel and am worried that somehow that has something to do with it, though I don't quite know how? Bad ground????![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
