rv8builder
Member
I am in the process of wiring the panel of my RV-8 to include a Garmin GNC 300XL system.
I have two questions about the wiring of the external switching required to make the device compliant with TSO 129a ClassA(1) (ie the GPS approach mode).
Question 1: The switch that is wired to pin 9 of J101 (the "GPS Approach Arm control)........should that be a simple "momentary on" switch??
Question 2: The swich that is wired to pin 13 of J102 (the "Sequence/Hold" control)......is that a SPST switch??
Thanks in advance,
Dale
Thanks in advance,
Dale
