Garmin GAD 27 not appears in System Information
Carlosanlley
Member
Friend
I'm at the stage of starting to test the avionics. The rest of the equipment has connected to the CAN bus network without any issues and with 0% error, but the GAD 27 doesn't appear in the System Information window. However, the status LED during the startup process is solid green, and after a few minutes, it starts blinking green, indicating that it is communicating with the CAN bus. Apart from this, in the Engine and Airframe configuration window, the GAD 27 tab is not visible, although the Flap and Trim motors are working. These are connected through the GAD 27.
I find it strange that the Flap and Trim functions are working, as well as the status LED indicating CAN bus connectivity, but I can't see anything regarding it in the G3X system. Any ideas where the problem might be?
G3x System was updated a couple of days ago to the latest firmware.
