dual Stewart Werner senders per tank wiring config
Okay folks I am driving myself crazy here. I cannot figure out how to wire up these senders. Here is my spefifics....
I have my RV10 Sky Designs ER tanks almost assembled.
I am using the Vans Stewart Werner floats. I opted out of CIES. I have added the additional outboard sender to the tank which only has a range as indicated in the plans from half to full. The IB sender has full range empty to full.
I was talking to Ken from SD and he pointed me to someone in AU who added a tank pass through fitting to the sender. I was told there is nothing like this available in the US?? WHAT IS THE POINT OF A PASS THROUGH GOING IN THE FLANGE OF SENDER... see this link from AU. If someone has another link for here in the US I would be appreciative.
https://www.efisolutions.com.au/electrical-bulkhead-terminal-submersible-e85-compa
I spoke with Garmin this morning and THEY told me I can run both IB and OB sender grounds together and have just one ground wire per wing side running up to the GEA24. ????????
AS FOR THE POWER I AM UNDER THE IMPRESSION I NEED SHIELDED WIRE 22AWG and I need to run power wires in a series formation to the GEA24. BUT HOW.....
SO WHAT I NEED HELP WITH IS DO I EVEN NEED A PASS THROUGH OR CAN I JUST RUN THE SHIELDED POWER WIRES WITHOUT IT THROUGH SERIES. IF SOMEONE CAN TELL ME SPECIFICALLY HOW THE POWER WIRES ARE RUN I WILL APPRECIATE IT. (do the power wires get tied together and then one power wire per wing side run to panel?????)
PARDON MY IGNORANCE HERE. I AM A FIRST TIME BUILDER AND LEARNING ALONG THE WAY. The dual senders in these ER tanks is not a normal config and its taking some research to figure out how I will do it for it to function and operate properly.
ANY HELP WILL BE GREATLY APPRECIATED
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
