Garmin G3X 650nxi G5 and GFC500 three beeps
932WT
Member
Sometimes in flight, it seems when climbing to altitude, I hear three beeps, three times. They are not 2 seconds apart like an ELT malfunction alert. I sent my ELT back for testing thinking it was the ELT low RF power alert. They said nothing was wrong with it. There are no annunciator or warnings that come with the beeps. In the G3X config mode I see no errors in the log. Anyone have an idea what this is?
If you have set an altitude to climb and cruise at you should get beep warning as you approach 1000' short of the set altitude and then another beep warning as you approach 200' from the set altitude. Could this be your beeps? You will also get beep warning if you leave the designated altitude by 200'. Altitude warning beeps. You mention it occurs in the climb.
No, it’s not the 1000 feet to go beeps. It’s a much higher tone and quicker. I don’t think it’s the 220 ft altitude deviation beep. And it only happens once in a while.
Do you have an ACK E-04 by chance?
Yes, that was my first thought so I sent it in to the manufacturer and they tested it and say it's fine. Plus the beeps are not two seconds apart. They are like 1/2 or 1 second apart. Three sets of three quick high pitched beeps. So I'm stumped. There are no warning annunciates and not fault codes I can find in the GSX setup mode.
If there's something making an unknown beep in an E-04 equipped RV, my money is on the ACK until proven otherwise! 🤣 I mean, at this point I'd actually be relieved to find something else was responsible. Keeping my fingers crossed.
Could be, but the manufacturer was insistent they checked everything… It happened again today when I was climbing and getting close to my selected altitude. It wasn’t the 1000 to go lower tone beep. I was within a couple hundred feet of the selected altitude. If I figure it out I’ll let you know!
Dumb question but: could it be a CO monitor?
Is it always occurring at a particular altitude?
One aircraft I fly makes the same 3 x 3 beeps when passing 10 000’ on climb. I assume in my case it’s a preset warning, dating from the days when oxygen was required above that level here in Oz. (Or, a reminder to set Standard on the altimeter, which is at the same level.)
The common factor is that it also has a G650nxi.
I do t think it’s always the same altitude, but maybe. I thinks it’s always been relatively high - like 9,000. I’ll note the altitude next time. It is a 650nxi.
That’s not a dumb question. I have a panel hard wired CO2 detector. I’ll push its test button and see of it’s the same sound. It happens only one on a while.
It’s not the same beep as the ELT test. It hasn’t happened in a long while but today, in Colorado while climbing hard to 13,000 from Longmont it happened again. And then again at startup at Leadville airport.
Do you have built in O2 or a portable bottle with an O2D2? I’ve heard beeps from it if I was at altitude and wasn’t consuming O2.
So it's not the built-in CO detector. When the beeps start the CO warning light is not on and it's not the same tone. It seems to happen ay higher altitudes only, often when nearing the selected altitude. And sometimes it's two series of three beeps and sometimes it's three sets of three beeps. Very strange. I can't figure it out.
I too get the three beeps In my Bonanza. We have an all new Garmin panel: G3X, GI 275, GFC 500, GMA 345, GTN 750xi, GNS 430W, and GTX 345. It happens about once per flight. It’s kind of loud and consequently a bit alarming. It’s not the ELT, CO detector, or altitude alert. It almost seems like it’s being generated by the audio panel. But I don’t know. It surprises me every time.
Is it happening near a big airport? Any marker beacons still out there?
It’s not a marker beacon sound. The three beeps happen in quick succession. When it happens seems kind of random. But, I would say it’s usually earlier in the flight rather than later. I just combed through the GMA 345 Pilot’s guide but I didn’t find anything.
Yeah, mine is alarming too. It's not a marker beacon, I'm pretty sure of that. I have a G3X touch, 650 NX, new blue tooth audio panel, G5, GFC 500 autopilot. Also a built-in CO detector. Does yours happen when climbing at higher altitudes, like 9000 feet?
Autopilot annunciation, maybe "trim required" or something else?
ds
I don't know. I see no annunciation and the autopilot runs the elevator trim with no apparent problems. I also have gone into the data logging card and I see nothing unusual there. Also nothing in the G3X setup mode in the alerts log. It does not happen every flight.
Hard to say because I’m almost always climbing to a higher altitude in the Bonanza. I’ll start paying more attention to when it actually occurs. I’m pretty sure it only does it once per flight.
