CWS
So this IS the AP disconnect wiring on the diagrams? Just hold for sync ? Sounds great thanks.
This is correct, with some important details to be aware of.
First, this is only true if the system is configured for CWS to be enabled (Configuration Mode > Autopilot Menu). If this setting is enabled, a short press and release of the AP/CWS button will disengage the autopilot if it is engaged. Pressing and holding the AP/CWS button places the autopilot into CWS mode. In CWS mode, the servos are temporarily disengaged, allowing the pilot to hand-fly the aircraft to a new aircraft attitude. When the AP/CWS button is released, the autopilot exits CWS mode and the flight director synchronizes to the current aircraft attitude (if applicable for the current flight director modes).
The
G3X Touch Pilot's Guide is a good reference for exploring how CWS will behave in relation to different flight director modes (Page 317 of Revision V). For example, ALT, PIT, and VS mode will capture the new altitude, pitch reference, or vertical speed reference when the CWS button is released. However, NAV and HDG mode return to the original reference after the CWS button is released. Each mode has unique considerations, we recommend reviewing this section of the Pilots guide before using this function.
Another configuration setting to be aware of is "Engage AP Via CWS Input" (Configuration Mode > Autopilot Menu). If this setting is enabled, a press of the AP/CWS switch engages the Autopilot. When this setting is disabled, a press of the AP/CWS button has no effect.
Please let us know if you have any other questions.
Justin
